Dataman 574 150 MHz USB Oscilloscope
Dataman 574
Dual channel oscilloscope with 150 MHz bandwidth and USB 2.0 connectivity. Dataman 574 is a small, fast and powerful oscilloscope offering many advanced features.
The 574 is built to meet the demands of development labs and field engineers for advanced PC based oscilloscopes.
Price: $ 1095.00
General
  • USB 2.0/1.1 compatible interface
  • Dual channel with external trigger
  • 150 MHz bandwidth
  • Deflection factor: 10 mV/div to 5 V/div in 1-2-5 sequence
  • Maximum real time sampling rate: 100 MS/s
  • Maximum equivalent sampling rate: 10 GS/s
  • Large internal sample buffer: 1,000,000 per channel
  • Powered from USB (no batteries or power adapter required)
Vertical Deflection System
  • No. of horizontal divisions: 8
  • No. of samples per division: 32
  • Deflection factor range: 10mV/div to 5V/div in 1-2-5 sequence
  • Accuracy: +- 2% of current value + 1 pixel
  • Resolution: 8 bits (0,39%)
  • Frequency response (-3dB): DC: 0-150 MHz, AC: 1.2 Hz-150 MHz
  • Step response rise time: max. 2.4 ns
  • Channel isolation: min. –60 dB
  • Resistance: 1 MOhm +5 %, -2 %
  • Input resistance inaccuracy adjustment: Digital for absolute accuracy +- 2% of current voltage + 1 pixel
  • Capacitance: 30 pF +- 2pF
  • Zero setting accuracy: +- 2% of the screen
  • Maximum input voltage: +- 200V at 100 kHz or less
Triggering
  • System type: Dual level
  • Trigger source for primary level: selectable Channel A, Channel B or external trigger input
  • Trigger source for secondary level: selectable Channel A, Channel B or external trigger input
  • Threshold setting: Channel A and Channel B on the whole display range. External fixed on about 1.5V
  • Slope selection: Leading or trailing edge independently on each source
  • Minimum trigger pulse period: 5 ns
  • Minimum trigger pulse length: 2.5 ns
  • Maximum voltage on external trigger input: -10V to +13V at 20 kHz or less
  • Adjustments: Digital filter with ability of setting the valid pulse length up to 131072*Ts for each level and counter of valid triggering events settable from 1 to 32768 for each level. HOLD-OFF settable up to 1048576*Ts with selectable AUTO mode, to sample proper amount of data before trigger. (Ts – actual real time sampling period)
Data Acquisition System
  • No. of horizontal divisions: 10
  • No. of samples per division: 50
  • Mode of operation: Sampling before and after trigger with continual selection of the trigger position
  • Record length: Settable from 1024 to 1048576 (1 M) samples for each channel
  • Time base range in 1:1 mode: 5 ns/d to 100 ms/d in 1-2-5 sequence
  • Time base range using different ZOOM modes: 625 ps/d to 204.8 s/d
  • Time base accuracy: 0.01 % to 100 ns/d, 0.5 % for 50 ns/d to 5 ns/d
  • Real time sampling frequency: 1 kHz to 100 MHz
  • Equivalent sampling frequency: 1 kHz to 10 GHz
  • Display range with respect to trigger event: 1048576 samples before and 1048576 samples after trig. event in length of 1048576 samples
Probe Compensation Generator
  • Output connector: BNC, together with External trigger input
  • Output impedance: 1 kOhm to parallel with 10nF and approx. 50 Ohm serial
  • Output waveform: Pulse with 1:1 duty cycle
  • Frequency: 1465 Hz
  • Output voltage (no load): 3.3V +- 5%
Related Products
570 Series Development Kit
More Information >
Price: $ 165.00
570 Series Roll Mode Software
More Information >
Price: $ 35.00
E26120 200 MHz Probe
More Information >
Price: $ 55.00
Cart
Buy online with McAfee Secure and Thawte SSL protection
Chip Search
Free resource of over 80,000 chips and 30,000 datasheets from 170 manufacturers.
Use our powerful forum to ask questions and share information.
Support
Need help / support?
We will respond in 24h to any support request
Software Update
Sign up to our software update email for details of the latest releases.
© Copyright 2010 Dataman. All rights reserved
