Benefits of the 48Pro2 Gang Programming SystemBy operating multiple 48Pro2 programmers from the same PC, you can create a high volume production environment with all the benefits of the standard 48Pro2 such as universal 48-pin ZIF socket, ISP capabilities and USB 2.0 connectivity. Up to four 48Pro2 programmers can be connected simultaneously providing a highly scalable gang programming system.
General
- Independent programming is more efficient than the concurrent programming method used in traditional gang programmers as each site operates independently allowing programming to start as soon as each device is inserted into the ZIF socket. Before the last device is loaded, the first device is already programmed and ready for removal. The operator is always busy removing and inserting chips, so both the operator and programmer are running continuously at maximum efficiency. With traditional gang programmer operation, the operator is idle while chips are being programmed and the programmer is idle while chips are being removed and new chips inserted. Therefore for the medium programming times, you can easily achieve the throughput of an eight socket gang programmer with two - four 48Pro2 programmers.
- 48Pro2 programmer offers the same advanced features as 48Pro+ programmer but with much higher programming speeds (20-75%) for high-capacity memories.
- FPGA based totally reconfigurable 48 powerful TTL pindrivers provide H/L/pull_up/pull_down and read capability for each pin of socket. Advanced pindrivers incorporate high-quality high-speed circuitry to deliver signals without overshoot or ground bounce for all supported devices. Improved pin drivers operate down to 1.8V so you'll be ready to program the full range of tomorrows advanced low-voltage devices.
- The programmer performs device insertion and contact tests before programming each device. These capabilities, supported by overcurrent protection and signature-byte check help prevent chip damage due to operator error.
- The selftest capability allows diagnostics included in the software to thoroughly check the health of the programmer.
- Built-in protection circuits eliminate damage to the programmer and/or programmed devices due to environment or operator failure. All the inputs of the 48Pro2 programmer, including ZIF socket, connection to PC and power supply input are protected against ESD up to 15kV.
- 48Pro2 programmer performs programming verification at the marginal level of supply voltage, improving programming yield and guarantying long data retention.
- Various socket converters are available to handle device in PLCC, JLCC, SOIC, SDIP, SOP, PSOP, SSOP, TSOP, TSOPII, TSSOP, QFP, PQFP, TQFP, VQFP, QFN (MLF), SON, BGA, EBGA, FBGA, VFBGA, UBGA, FTBGA, LAP, CSP, SCSP, LQFP, MQFP, HVQFN, QLP, QIP and other packages.
Programmer Specification
- 1 x universal programming module (1 x 48-pin DIL ZIF socket and 1 x ISP connectors)
- Operation result LEDs, LED power
- USB 2.0 high-speed compatible port
- FPGA based IEEE 1284 slave printer port
- Protection against surge and ESD on power supply input and parallel port connection
- Banana jack for ESD wrist strap connection
- Banana jack for connection to ground
Module SpecificationBase Unit (DAC)
- On-board intelligence: powerful microprocessor and FPGA based state machine
- Three D/A converters for VCCP, VPP1, and VPP2, controllable rise and fall time
- VCCP range 0..8V/1A
- VPP1, VPP2 range 0..26V/1A
- Selftest capability
ZIF Socket
- 48-pin DIL ZIF socket accepts both 300/600 mil devices up to 48-pin
- Pindrivers: 48 universal
- VCCP/VPP1/VPP2 can be connected to each pin
- Perfect ground for each pin
- FPGA based TTL driver provides H, L, CLK, pull-up, pull-down on all pindriver pins
- Analog pindriver output level selectable from 1.8V up to 26V
- Current limitation, overcurrent shutdown, power failure shutdown
- ESD protection on each pin of socket (IEC1000-4-2: 15kV air, 8kV contact)
- Continuity test: each pin is tested before every programming operation
ISP Connector
- 20-pin male type with missinsertion lock
- 6 TTL pindrivers, provides H, L, CLK, pull-up, pull-down; level H selectable from 1.8V up to 5V to handle all (including low-voltage) devices
- 1x VCCP voltage (range 2V..7V/100mA), can be applied to two pins
- Programmed chip voltage (VCCP) with both source/sink capability and voltage sense
- 1x VPP voltage (range 2V..25V/50mA), can be applied to six pins
- Target system supply voltage (range 2V..6V/250mA)
- ESD protection on each pin of ISP connector (IEC1000-4-2: 15kV air, 8kV contact)
- Two output signals, which indicate state of work result = LED OK and LED Error (active level: min 1.8V)
- Input signal, switch YES! equivalent (active level: max. 0.8V)
